Hello!
I am facing an issue with my model. I have a variable
A(index1,index2,index3,index4)
and I am defining another variable
B(index2,index3,index4) as max(index1, A(index1,index2,index3,index4))
However, while running the model, it gives an error that the the model become non linear. Is there a way to work around this?
Regards,
Vishwesh Patil
Hi @vishweshpatil,
could you not add a new constraint ensure_B_larger_than_A  with index domain (index1, index2, index3, index4) and as definition
B(index2, index3, index4) >= A(index1, index2, index3, index4)
Assuming that the goal for the model is to drive the value of B down, this would ensure that B will always be greater or equal than the largest value of A.
Hi @vishweshpatil , and if the model does not have the intention to make B as low as possible then you can use reformulation 2.3 from this document.
Hi @vishweshpatil
Did @gdiepen ‘s answer help you with your question?
Best
