Looping Execution Array
  • October 18, 2022
  • 125 views
I'm trying to do some sensitivity runs where I scale a parameter each run and resolve.
The problem is I can't seem to very simply make an array to loop over to scale the parameter.
Basically this:
FOR x in [50, 75, 100] DO
   y = x * z;
   solve LP;
ENDFOR
Just creating the array and looping through it is giving me trouble. I don't know the best way - import the array as a parameter? Then it gets mad it doesn't have an index? But it doesn't even really have an index. Then x has to be a declared parameter as well?
Is there an easy way to do this or maybe it's because AIMMS isn't made for scripts? I can't seem to find a syntax guide that talks about declaring an array parameter.
Thanks for helping a noob!
Best answer by Chris Kuip
You are almost there: just replace [ ] with { } in your code.
I created small example:
Here x is declared as an index with range Integers, and y and z are two parameters.
This gives the following listing file:
For your convenience, I've attached the AIMMS 4.88 project.
With kind regards,
Chris.
Chris Kuip
  • October 18, 2022
With kind regards,
Chris.
  • October 21, 2022
Thanks Chris! That did it.
