{i| sum((p,yr),TLin(i,p,yr)) <> 0}
Warning: The units associated with the expression (sum( ( p, yr ) , TLin(i,p,yr) ) )[m3], and with the expression (0)[] are not commensurate.
Is there a trick to get around this? I know I can define a parameter with a value 0 and unit m3, but do not want add modelling complexity for such a minor issue.
Any suggestions are welcome.
With kind regards,
Binod
Best answer by mateusarakawa
Hi, @bkoirala .
You could write:
Hope it helps!
You could write:
code:
i| sum((p,yr),TLin(i,p,yr)) <> 0 [m3]
Hope it helps!
