measurement units
  • 7 August 2019
  • 122 views
Userlevel 1
Badge
I have following unit consistency warning for the expression below:
{i| sum((p,yr),TLin(i,p,yr)) <> 0}
Warning: The units associated with the expression (sum( ( p, yr ) , TLin(i,p,yr) ) )[m3], and with the expression (0)[] are not commensurate.
Is there a trick to get around this? I know I can define a parameter with a value 0 and unit m3, but do not want add modelling complexity for such a minor issue.
Any suggestions are welcome.
With kind regards,
Binod
Best answer by mateusarakawa 7 August 2019, 14:22
Badge +2
Hi, @bkoirala .
You could write:
code:
i| sum((p,yr),TLin(i,p,yr)) <> 0 [m3]
Hope it helps!
Badge +2
Another ideas that could be useful for you in the future:
You can read about the function mapval: http://aimms.com/files/3914/5566/1567/AIMMS_func.pdf
or use some syntax like: "i | not sum((p,yr),TLin(i,p,yr))". But you should be careful using "not" beacause it considers the default of the parameters, if I recall correctly.
Userlevel 1
Badge
Thank you @mateusarakawa, very useful!
