In the attached model, you should only run the procedure ReadFromExcel. This should load all the relevant sets and parameters.
When I try to solve this model, I encounter different memory errors. I either see:
- Memory allocation error
- Memory allocation error: while assigning "xxx" bytes
Kind regards,
Koen
