Modify DSN to Conect Acess
  • January 20, 2021
  • 6 replies
  • 173 views
Good morning.
I am converting our proyects in AIMMS from version 3 to version 4 and the DSN that already was used to connect to Access has failed.
I used the extension (*.mdb), also tried with  (*.accdb) but doesn´t work.
Could you help?
Thanks a lot
Best answer by deannezhang
Could it be something related to what is mentioned in this article https://how-to.aimms.com/Articles/129/129-MSACCESS-32bit-64bit.html ?
deannezhang
  • January 20, 2021
  • January 21, 2021
Thanks a lot, we are using Office 365 32 bits. And AIMMS 4 64 bits. I believe
that might be the problem.
  • January 25, 2021
It seems impossible to connect AIMMS 64 bits to Access data (32 bits) through the DSN conector.
How should I modify the DSN?
Thanks a lot
Dear Sonia,
After .mdb on the last line of the dsn file I added an X, so:
.mdbX
In my case it works.
Good luck!
Joost
  • January 25, 2021
Dear Sonia,
.mdbX
Good luck!
Joost
Thanks a lot but it doesn´t work yet ;(
Are you using Office 2010 ? In my case is Office 365 (32 bits)
I'm using Office 365 but 64 bits. When I used 32 bits before I used a 32 bits version of AIMMS and a 64 bits version. I read in the database using 32 bit, stored the data in a case, closed AIMMS 32 bits, opened AIMMS 64 bit and read in the case. This is of course quite cumbersome.
