More colors in pie chart legend
  • 13 July 2020
  • 92 views
Badge
Hi.
I am trying to plot a pie chart in a user interface. The colors repeat for different pie sections as can be seen in the attached image.  How do I set different colors for different pie sections. Thanks.
Best answer by mateusarakawa 13 July 2020, 22:34
Badge +2
Hi @Suj8epri.
I’m assuming you are using 2D chart object - type “pie”.
On its properties, under “display”, you can set a color scheme created by you:
You can create a new scheme color by color using “New” and “Change Color” buttons:
Or you can work with subsets, like I did here:
I’m using a set created by me, called “S_GUI_CoresDisponiveis”:
And these colors, I think I might have created using “User Color” tool:
Hope it helps!
Badge
This is very detailed!! Thanks, Mateus.
