my small program give a wrong result
  • March 14, 2020
  • 182 views
Dear all
My mathematical problem is to schedule the device in a home to achieve the minimum cost during a day. I divide a day into 24 time slots.  Each device with have its own Power rate and length of operation time. Main variables in my problem are starting time of devices at which a device is started to run. When I run my program, starting times of devices are always at time slot 1 and these are wrong results. I do not know why my program give wrong results.
Here is my program
Model Main_Test_starting_time {
    Set Time {
        Index: t;
    Set Devices {
        Index: d;
    Parameter Price {
        IndexDomain: t;
    Parameter Power_rate {
        IndexDomain: d;
    Parameter Length_of_operation_time {
        IndexDomain: d;
    Variable Starting_time {
        IndexDomain: d;
        Range: {
            {1..inf}
    Variable Energy_consumtion {
        IndexDomain: t;
        Range: nonnegative;
        Definition: sum[d, if Ord(t) >= Starting_time(d) AND Ord(t) <= Starting_time(d) + Length_of_operation_time(d) - 1 then Power_rate(d) else 0 endif];
    Variable Total_cost {
        Range: free;
        Definition: sum[t, Energy_consumtion(t) * Price(t)];
    Constraint Contraint {
        IndexDomain: d;
        Definition: Starting_time(d) <= Card(Time) - Length_of_operation_time(d) - 1;
    MathematicalProgram Minimum_Total_cost {
        Objective: Total_cost;
        Direction: minimize;
        Constraints: AllConstraints;
        Variables: AllVariables;
        Type: Automatic;
Please help me
Thank you very much
The wrong results is likely because you are using the variable Starting_time(d) as the condition of an IF block. From the formulation, looks like a device can be turned on only once during the day ? Using binary variables to represent on/off states is a very common formulation practice. Can you test your data on the attached model ?
  • March 17, 2020
  • Newcomer
  • March 18, 2020
Thank you very much for your help. I learn a lot from your code.
Now I know that we should avoid using if.. then..else as much as possible in mathematical program.
