Parameter for solving status
  • 17 July 2023
  • 34 views
Badge +4
Hi all, I am going to run the AIMMS with many different scenarios(case data) automatically. In case the solver may not find the optimum solution in some of the scenarios, I wonder is there any parameter or index (such as 0 or 1) I can get after solving each case to indicate if the solver has got the optimum solution?
Best answer by Marcel Hunting 18 July 2023, 09:10
Badge +4
Hi @Chunyang. You can use the math program suffix ProgramStatus for this. If it equals ‘Optimal’ then an optimal solution has been found.
