RegexReplace For On-Premise PRO path
  • 14 February 2023
  • 49 views
Userlevel 1
Badge +4
Hi Community,
I am trying to use the AIMMS RegexReplace function to trim the folder path and keep the data case name. It’s working fine locally but it’s not working when testing in the server.
My code looks like this:
        block ! Get the full path for the Active Case File
            _sp_ActiveCasePathName := FormatString("%s", CaseFileURL(CurrentCase));
            !Check for server vs local. Local path won't likely contain the string 'PRO:/PublicDta'
            !example server path: PRO:/PublicData/Cases/spot_fw
            _bp_IndicateLocalFileName := not (RegexSearch(_sp_ActiveCasePathName,         "PRO:\\\\PublicData"));
            ! Text example _sp_ActiveCaseName := "C:\GitHub\spot-fw\Model Folder\data\DataCase_C5AgeTest_Output.data"
            ! This Removes the structure
            !local: C:\\Location_of_File\With general\ideas-of-how\afilesnamewouldbe\
            !in the server: pro:/PublicData/Cases/FW SPOT Testing/
            !before the actual file name
            if _bp_IndicateLocalFileName then
                _sp_ActiveCaseName := RegexReplace(_sp_ActiveCasePathName, "C\\:\\\\([\\-\\_\\ [:alnum:]]+\\\\)+", "");
            else
                _sp_ActiveCaseName := RegexReplace(_sp_ActiveCasePathName, "[Pp][Rr][Oo]\\:\\\\([\\-\\_\\ [:alnum:]]+\\\\)+", "");
            endif;
        endblock;
            else
            endif;
        endblock;
Any ideas/help on what might be going wrong with the server file structure?
Thanks in advance!
Best answer by MarcelRoelofs 16 February 2023, 10:07
Userlevel 4
Badge +5
Hi @Diego Perez-Urruti
Well, the first thing I noticed is some confusion about how pro: paths are written. In your comment you use forward slashes, but your regular expressions use backward slashes. The documentation mentions forward slashes, so this may be the cause of your problems.
Alternatively, you could just use FindNthString to find the last forward/backward slash, and take the substring starting one position to the right.to find the case name.
Userlevel 1
Badge +4
Hi Marcel,
Thanks for the follow-up. We did try using forward slashes but that didn’t do the trick either. Seems like we are missing something to capture the server file strucutre usign regex.
Any other advise for regex or would you recommend just switching to the findstring/substring method?
Thank you!
Best,
Diego
