In our project we set options manually. For example, we have lines of code like ‘option CPLEX_22_1.integrality := 1e-05;’. For a specific case that we have, we would like set all these options to their default values and run the case again. What procedure can we use for this?
Two things we tried that did not work:
- We cannot just remove all lines of code where we manually set options, since the case that we have problems with has been run before; hence, the default options in this case have already been overridden.
- We also tried using the procedure ‘OptionGetValue’ to get the default value and set every option to its default value, but this does not work for the majority of our options. For example, when applying our procedure to the option ‘Advanced_Start’ we get the error ‘Option not found, or not a numeric option’. Another example is the option ‘CPLEX_22_1.integrality’; in that case we get the error ‘The option “CPLEX_22_1.integrality” has not been found’.
Thank you!
