Right modeling question
  • August 4, 2023
  • 170 views
Good day to you.
I am modeling a situation in AIMMS and I have a situation but do not know how to handle it.
The situation is that I am modeling variable 'P_Discharging(agg,t)' and I do not want it to discharge after the battery gets to <= 0.3501 and at the same time, variable 'P_Charging(agg,t)' and I do not want it to charge at >= 0.949. To achieve this, I have these figures:
My main aim is to formulate a linear program. Just asking if what I have done is right or if I should model it using a 'Constraint' rather than ‘variable’. Moreso, I do not know how to model it into a 'Constraint'. Please, can you help me look into this?
Thank you.
Olusegun
hi @olusegun.adeniji. Seems to me that you want to model for P_Discharging(agg,t): If SOC(agg,t-1) < 0.3501 then P_Discharging(agg,t) = 0.
Linear models cannot handle strict inequalities (<) so you have to use some kind of small (epsilon) value to transfer them into <=.
For P_Discharging(agg,t) you need a new binary variable, say X(agg,t). Then you need these new constaints:
SOC(agg,t-1) <= 0.3501 - eps + M*X(agg,t)
SOC(agg,t-1) >= 0.3501*X(agg,t)
Here M is some big value and eps a small (positive) value close to 0. Now you need one more constraint, namely
P_Discharging(agg,t) <= M*X(agg,t)
Now we have modelled:
  • If X(agg,t) = 0 then SOC(agg,t-1) <= 0.3501 - eps, and P_Discharging(agg,t) = 0.
  • If X(agg,t) = 1 then SOC(agg,t-1) >= 0.3501.
The current definition of P_Discharging should be removed.
The variable P_Charging you can be reformulated in a similar way.
Thank you for your prompt response. I have implemented the P_Charging part as follows:
SOC(agg, t -1)  >=  0.949 + eps + M*Y(agg, t);
SOC(agg, t - 1)  <=  0.949 * Y(agg, t);
P_Charging(agg, t)  >=  M*Y(agg, t).
So if:
  • Y(agg, t) = 0, then SOC(agg,t)  >=  0.949 + eps, and P_Charging (agg,t) = 0
  • Y(agg, t)  = 1, then SOC(agg,t)  <= 0.949.
But when I used a high value for M in the formulation, it returned that a high value cannot be implemented.
Olusegun
I think you should be using
P_Charging(agg, t)  <=  M*Y(agg, t).
(so different type). The M does not have to be very large. It suffices to make the M in the first constraint equal to an upper bound on SOC, so you can use Max_SOC(t). The M in the third constraint can be equal to Max_P_Discharge, because that defines an upper bound on P_Charging.
By design, I modelled the P_Charging to be negative while P_Discharging is positive. So, the range of P_Charging is ((Min_Active_Power(agg, t), 0) while the range of P_Discharging is (0, Max_P_Discharge(agg,t)). The range of SOC(agg,t) is (Min_SOC(t), Max_SOC(t)). Both the ranges on SOC(agg, t) are positive.
So I think this will be finally right:
For Discharging:
SOC(agg,t -1) <= 0.3501 - eps + (Min_SOC(t) * X(agg,t))
SOC(agg,t -1) >= 0.3501 * X(agg,t)
P_Discharging(agg,t) <=  Max_P_Discharge(agg,t) * X(agg,t)
For Charging:
SOC(agg, t -1)  >=  0.949 + eps + Max_SOC(t) * Y(agg, t);
P_Charging(agg, t) <= Min_Active_Power(agg,t) * Y(agg, t).
I would appreciate if you could make necessary comments on the above formulation.
Thanks
