Round function with Units of Measurent
  • 10 November 2021
  • 48 views
Badge
Hi, I seem to have difficulties with defining the number of decimals when rounding my parameters . The function description tells me I should define a positive integer for defining the number of decimals on the right of the decimal point, but this function gives me a different number of decimals. I use Units of Measurement and I think the ‘internal’ unit is rounded instead of my defined unit for the specific parameter (which differs in order 6 (10^6) ). Do more people encounter this problem?
Best answer by mohansx 10 November 2021, 21:34
Badge +5
@anneke-vries are you using this round function in a definition or assignment statement ? Can you share the declaration of your usage ? (either screenshot or text representation).
Also verify that the value of option `rounding_compatibility` is set to AIMMS 3 7
