Hi all,
I am modelling production routes per production order in which the production routes provide the sequence of the jobs to follow.
I created a subset ProductionRoute(i) that is a subset of all possible jobs.
See below a production order i that follows the sequence: SMD → AOI → REW.
When implementing this in the subset and when running the model, it will follow the sequence AOI → REW → SMD since operations is stated ascending. Such as below.
Is there a possibility to model in AIMMS that it should follow the production route as stated in the first figure? Instead of looking to the ascending order of the subset.
Best answer by Chris Kuip
