Substitute for "sumproduct" Function in Excel
  • 16 March 2022
  • 56 views
Badge
Hey Guys,
I have a small problem by modeling my MILP.
I created a Matrix do define some Binary Variables. Now I want to create a constraint, which contains a multiplication between the Matrix of the Variables an a Matrix with some parameters. The result should be a scalar value comparable to the sumproduct-function in Excel. I want to do a multiplication between the matrices an the result should be a scalar?
Hopefully there is a simple function in Aimms to solve my problem.
I am thankful for every help!
Best regards
Simon
Best answer by gdiepen 16 March 2022, 22:02
Badge +7
If the variables and the parameters share the same indices, this could be done with
sum( (indexOne, indexTwo), yourParameter(indexOne, indexTwo) * BinaryVariable(indexOne, indexTwo))
If this is not what you mean, then please clarify a bit what you want to achieve
Badge
Thank you really much. I had a small mistake in the indices, which caused some problems in my Model.
Thanks a lot!
