summation over subset of an index
  • February 28, 2023
  • 122 views
Hello everyone,
I’m new in AIMMS and need help for my thesis.
I need to implement the following constraints:
t is an index for the period, here t = ( 1,2,3,…,T )
  1. How can i set the initial value from E(t=1) = Q
  2. How can I implement the E(T+1)
Thank you in advance
kind regards
Best answer by gabiservidone
Hi Marv,
  1. You can either:
    1. create a element parameter with the first element of the set defined and use it as: E(elementparameter) = Q
    2. or add a domain E(t) | t=1 = Q
  2. if T is a index of a set, you can do excatly that t+1 and the result will be the next element of that set.
We do have 2 courses about modeling in AIMMS, this will be helpfull!
https://academy.aimms.com/course/view.php?id=35
https://academy.aimms.com/course/view.php?id=53
  • March 10, 2023
Hi Marv,
  1. You can either:
