Hi! Does anyone know how to interrupt the calculation process and display the current results?
Termination of the computing process
Best answer by Mischa
Hi!
You can use the key combination CTRL+SHIFT+S in AIMMS during (long) calculations. It will show a dialog asking you whether you want to interrupt the current run or just the solve and allows you to start debugging too.
With kind regards,
Mischa
