The symbol ";" is not expected.
  • 6 July 2022
  • 127 views
Badge +4
Good day people….i am new to AIMMS. I want AIMMS to read from a dat file but it keeps giving me the  statement “The symbol ";" is not expected.” The content of the dat file is
COMPOSITE TABLE:
G  M P R_M R_P
10 8 4 10  15 ;
after removing the symbol ; it pops up another error which is ‘The symbol "15    " is not expected.’
after removing 15, it pops up another error which is ‘The symbol "10     " is not expected.”
Is there something i am not getting right on how to structure the contents in dat file. Kindly help please.
Best answer by Chris Kuip 6 July 2022, 19:55
Badge +7
Hello Lawrence,
I tried to reproduce the behavior you described, but failed; when you open the enclosed project, and press the ME button, the data is read in as follows:
After pressing the ME button in the enclosed app.
May I ask:
  1. Does this behavior persist after restarting AIMMS?
  2. Which AIMMS version are you using? (I am using AIMMS 4.86.8)
  3. If the behavior persists, how are G, M, P, R_M, and R_P declared?
With kind regards,
Chris.
Badge +4
Thank you Chris.
I am using 4.85.6.21.
G, M, P, R_M & R_P are declared as scalar parameters.
After restarting, it pops up the message below.
The file "Data\bottle" cannot be opened: No such file or directory.
Find attached the work folder.
Badge +7
Hi Lawrence,
Parameters without an index domain are not supported by the composite table.  Please use assignments instead; for instance the following works:
G := 10 ;
M := 8 ;
P := 4 ;
R_M := 10 ;
R_P := 10 ;
A working copy of the project is included.
Hope that helps,
Chris.
Badge +4
Thank you Chris.
It works. You could just help with the format to write to dat file. Thank you.
