use of If-Then-Constraint
  • October 20, 2021
  • 7 replies
  • 419 views
 Good morning all,
Please, can someone tell me why I keep getting this error :point_down_tone4:? Both SOC(agg,t) and P_Charging(agg,t) are variables.
Thanks so much.
@olusegun.adeniji
The problem is with your “else” block. This is a constraint and not a variable definition, so
else
P_Charging(agg, t)
endif
does not make any sense. You can simply have
IF SOC(agg, t-1) > 0.949 THEN
P_Charging(agg, t) = 0
ENDIF
  • October 20, 2021
@olusegun.adeniji
else
P_Charging(agg, t)
endif
ENDIF
Thanks @mohansx for your response.
Thanks @mohansx ,
I tried that suggestion and  it still gives error of missing “ELSE” part. Sincerely this looks so simple to tackle personally considering what I have done in AIMMS but I really dont know why I cant resolve it. Any further help would be greatly appreciated.
Thanks
  • October 21, 2021
Hello @olusegun.adeniji
Apologies, I missed that AIMMS requires IF blocks in constraints to have ELSE conditions too.
You have two options -
  1. Create another variable with same index domain as P_Charging(agg, t), call is temp_Charging(agg, t). Give it the below definition
    0
    ELSE
    P_Charging(agg, t)
    ENDIF
    Use temp_Charging(agg, t) in the objective function or other constraints/definitions instead of P_Charging.
  2. Use the modelling trick described in section 7.4 of the AIMMS Optimization Modelling guide.
    Your requirement is SOC(agg, t-1) > 0.949, then P_Charging(agg, t) must be 0 → which is equivalent to only one of SOC(agg, t-1) <= 0.949 and P_Charging(agg, t) <= 0 can be true.
    use a binary variable Y(agg, t) and upper limits for SOC - U1 and upper limit for P_Charging - U2. Introduce two constraints with index domain (agg, t)
    constraint1
    SOC(agg, t-1) <= 0.949 + U1 * Y(agg, t)
    constraint2
    P_Charging(agg, t) <= 0 + U2 * (1 - Y(agg, t))
If SOC(agg, t-1) needs to be greater than 0.949, Y(agg, t) must be 1 which will force the second constraint to become P_Charging(agg, t) <= 0 + 0 = 0 (assuming the range of P_Charging is nonnegative).
I hope this helps.
Hello @mohansx ,
Thanks for your response. My system went for some maintenance and just returned with it. I will let you know if your suggestion solves my problem.
Thanks again
Olusegun
Hi @mohansx ,
Sorry to bother you again on the above subject.
Please I want to ask what happens if range of P_Charging is nonpositive, that is it must be negative or zero?
Please, what will now be U2?
Thanks in advance for your prompt response.
Olusegun
  • November 18, 2021
@olusegun.adeniji In that case, instead of upper limit U2, you use the lower limit of P_Charging with range [L2, 0].
will become something like
P_Charging(agg, t) >= L2 * (1 - Y(agg, t))
When Y is 0, this will be P_Charging >= L2 and when Y = 1 - P_Charging >= 0 which will force it to be P_charging = 0 because of the range L2 <= P_Charging <= 0
