3 index domain for a parameter
  • May 20, 2019
  • 336 views
I'm a beginner and I know nothing about programming so Im just basing everything from the user manual.
I have a parameter with a "nC' as identifier and index domain: v,t,w. The problem is when I try to save it there's an error saying "The symbol ";" is not expected." How do I fix this?
Looks like you typed a ";" where it is not expected. If you double click on the error message, it will take you to the location of the error.
Can you delete the ";" in that location ?
If you intended to type the ";" there, then it is incorrect usage. We can recommend the proper usage if you can share a screenshot here.
  • May 20, 2019
  • Newcomer
  • May 29, 2019
Thank you! I just deleted the ";" I guess i typed it incorrectly
