AIMMS 4.97 warning in predeclared procedure
  • Nov 8, 2023 3:48 PM UTC
  • 85 views
Dear AIMMS,
I get the following warning about a predeclared procedure when opening AIMMS 4.97 "Warning: The 'queryMap' argument has a dimension mismatch. This will be treated as an error in a future AIMMS versions. Perhaps the argument should be declared as a Handle.”
How can this be solved?
Regards, Marit
Best answer by Curious AIMMS-bot
Hi Marit,
If I'm not mistaken, you are using the AIMMS Repository library Data Exchange. Is that correct?
If so, can you update to the latest version of that library?
With kind regards,
Chris.
Curious AIMMS-bot
Forum|alt.badge.img+1
Hi Marit,
With kind regards,
Chris.
  • Nov 9, 2023 9:00 AM UTC
Thank you Chris, that was the trick!
