Binary variable have fractional value
  • May 27, 2020 4:28 PM UTC
  • 228 views
Hi
I am using AIMMS for solving a planning problem in electrical engineering field. The optimization problem is a MILP. I have some variables that are defined to be binary but when the AIMMS solve the problem some of the binary variables have fractional values, which is weird.
I should mention that the relax status is used for solving linear version of MIP, but in the case that I am talking about the relax status variable is set to zero to have binary answers. Most of the answers are binary except for some of them that have fractional values.
I would be grateful if someone could help me to solve this issue.
Hi @rezakhalili Do these binary variables have fractional values close to 0 or 1? If not then it would help if we could investigate your project. Would it be possible for you to add your project here, preferably after adding it to a zip file, or send it to our support by email if your project contains sensitive information?
