calendar subset writing to file with dex
  • Jan 31, 2024 9:39 AM UTC
  • 149 views
Hi All,
I’m trying to write a parameter with dex using dex::WriteToFile() procedure. The parameter has an index year that is a subset of the calendar year. (simple calendar with unit year).
The excel download won’t fill the year column (see screenshot below). I have the latest .dex library 23.1.1.2).
Could anyone explain what went wrong here?
Best answer by Mischa
Hi Marc,
Thanks for sharing this observation!
I tried out what you describe and I ran into the same problem as you. It does work fine if you use the year calendar directly (as opposed to using the subset of it), I found.
I will file a ticket in our internal system to have this investigated.
(For those interested, I attached my small example project).
Kind regards,
Mischa
Mischa
  • Jan 31, 2024 3:03 PM UTC
Hi Marc,
Kind regards,
Mischa
MarcelRoelofs
This was a regression caused by recent conflicted merges because of the upgrade of our build system for AIMMS 24. It is fixed in DEX 24.0.0.13
