callback is called at each iteration but not the last!
  • Oct 20, 2021 1:27 PM UTC
  • 73 views
Hi, I have a problem with the callback procedure that is called at each iteration but  not the last.
At each iteration, the callback is  called, if the solution violates the constraints, the cuts are generated
and added to the model, but in the last iteration the callback is not  called at all, so the feasibility is not checked and the optimal solution provided by (cplex or gurobi, I tried both) is  in fact infeasible.
This  is  a scheme of  the  code:
GMPRelaxedModel := GMP::Instance::Generate(NoEnergy_per_lazy) ;
GMP::Instance::SetCallbackAddLazyConstraint( GMPRelaxedModel, 'Robust_NogoodCut' );
GMP::Instance::Solve( GMPRelaxedModel );
Hi @pira1338 , It is a bit hard to tell what is going on without having the AIMMS project. Would it be possible for you to add your project here, preferably after adding the complete project folder to a zip file, or send it to our support by email if your project contains sensitive information?
