callback procedure that saves new incumbent solution to case file
  • Jun 6, 2019 7:20 AM UTC
  • 232 views
Is it possible for a callback procedure to save the newest incumbent solution to a case file.
Is an example available?
Edit:
I already installed a callback procedure (SetCallbackNewIncumbent).
How can I access the new incumbent solution from that procedure?
And do I need to send the new incumbent solution to the model first, after which I can send it to a case file, or can I send it to a case file directly?
Best, WM
Best answer by deannezhang
In the callback procedure, you can first use function RetrieveCurrentVariableValues to retrieve the variables value from the model;
code:
RetrieveCurrentVariableValues(AllVariables);
Then use the .Incumbent suffix to retrieve the new incumbent value
code:
MyVariable.Incumbent;
Then use function like CaseFileSave to save those values you need.
deannezhang
  • Jun 7, 2019 3:16 AM UTC
code:
code:
  • Ace
  • Jun 11, 2019 9:26 PM UTC
Thanks for your answer, however I get this error...
The function RetrieveCurrentVariableValues cannot be called from a callback issued by GMP::SolverSessionExecute or GMP::SolverSession::AsynchronousExecute.
Any alternatives?
Thanks, W.
deannezhang
  • Jun 14, 2019 8:33 AM UTC
Hi Wiet, in this case, you may need to use function GMP::Solution::RetrieveFromSolverSession
  • Ace
  • Jun 17, 2019 10:04 AM UTC
Great, thanks!
