Cannot open case
  • Jun 22, 2020 2:46 AM UTC
  • 217 views
rahmat
Dear All,
I did a save as to a new case and run the model again. However, I cannot open the new case and the dialog box said that “is not an AIMMS case file” as shown in following figure.
Is there a way to fix this?
Many thanks.
Best answer by Anonymous
@rahmat , can I suggest to either add your project here or send it to support. It will be very hard to answer this question as such. Maybe it got corrupted during the save. Please add instruction on how to create the case and the steps you are taking if you decide to do either of this.
PS: Not sure how much data you expect to store and whether you have enough hard-disk space on your machine.
  • Jun 25, 2020 1:30 PM UTC
Andrew
  • Jul 6, 2020 9:11 PM UTC
Hi @rahmat
Were you able to figure out the solution yourself or through support?
Please upload your project and instructions on how to create the case if you are still unsure.
Best
rahmat
  • Ace
  • Jul 7, 2020 1:59 AM UTC
Hello @Andrew ,
AIMMS support has provided solutions to the problems.
Thank you very much.
