Cannot run 4.37 version project in 4.77 or beyond
  • Mar 27, 2024 4:30 PM UTC
  • 139 views
I am trying to open a project that was originally written in version 4.37. However I have a Community License so the earliest version I can use is 4.77. I have tried opening this project in both 4.77 and 24.2 and both will crash upon opening the project with no error message.
I understand the large difference in versions may be causing an issue but I have no way to test on earlier versions. Is there any way I can identify what exactly is causing this issue and could it be something other than a version issue?
Hi @JoeSkellern. If you can add your project here, preferably after adding it to a zip file, then we can try to convert it to the latest AIMMS version. If your project contains sensitive information then you can send it to our support by email.
  • Mar 28, 2024 2:58 PM UTC
Hi @Marcel Hunting, thank you for responding. I will send to your support team.
