Check if an element parameter has a value
  • Aug 4, 2022 4:07 PM UTC
  • 267 views
Hello everyone,
I have an Element Parameter PredecessorOperations(i_operation) that holds the value of the operation that has to be executed before i_operation. With the following statement i want to check if the EP has a value or not:
if (val(PredeccesorOperation(i_operation)) = 0) then
endif;
However this only works if all values of the Ep are empty. If any operation gets assigned a predeccesor (e.g. Operation1) then i get the error: Cannot compute the value of string “Operation1”.
If I would casually formulate the code it would look like this:
if( PredeccesorOperation(i_operation) is empty ) then
endif;
So my question is: What operator do I need to use in order to check if the parameter has any value or no value assigned?
I am thankful for any advice you might have.
With kind regards
Andrew
Best answer by Chris Kuip
Hi Andrew,
You can check whether predecessorOperation(i_operation) is empty by checking against the empty element '':
if predecessorOperation(i_operation) = '' then
endif ;
Hope this helps,
Chris
Chris Kuip
  • Aug 5, 2022 6:01 AM UTC
Hi Andrew,
endif ;
Hope this helps,
Chris
