Complex value assignment efficiency problem
  • Apr 11, 2025 12:24 PM UTC
  • 111 views
Hi I am trying to do a value assignment in AIMMS. Here is the example:
t and i are both the index of set time. n and r are the index for set Node. NodeInTime, needed_value are predetermined parameters. scenario is parameter changing in the process. noted_scenarios_index is a subset of Node. path is a mapping between index (r,t) and set Node.
for (n,t)| t<>first(time) and n<=NodeInTime(t) do
   scenario := 1;
   noted_scenarios_index := {r | r <= NodeInTime(t) and path(r, t) = n};
   for r in noted_scenarios_index do
        needed_value(scenario, n, t, i) := value(path(r,i), i);
        scenario := scenario + 1;
   endfor;
endfor;
I used debug move to check and surprisingly, the slowest part is:
when it runs to this line, ‘scenario’, ‘n’, ‘t’ are determined and it took more than 30s to run this line….. So I don’t understand why it’s so slow.
I also tried using an additional parameter like:
addition(i) := value(path(r,i), i);
needed_value(scenario, n, t, i) := addition(i);
and  addition(i) := value(path(r,i), i); runs quite fast.
However, needed_value(scenario, n, t, i) := addition(i); still runs very slow.
Can you give me some suggestion on how to improve the assignment speed?
Chris Kuip
  • Apr 16, 2025 9:04 AM UTC
Hello Chunyang,
The AIMMS parallel sparse execution engine is designed to handle large amounts of sparse data quickly.  As a consequence, each time the execution of an assignment statement starts, there is some preparation time.
The tactic to write efficient code is to avoid for loops -
let each execution of an assignment handle as much data as possible.
For the example at hand, Inside the for loops the input identifiers nodeInTime, p_value, and path do not change, and the parameter scenario and set noted_scenario_index are merely used as temporaries.
Instead of re-using these temporaries many times, the following code expands their use
over the domain (n,t) of valid tuples; consequently avoiding repeated assignment preparation times.
Adapted code
I didn't have data, so I cannot predict the time / memory effect of this code change for your application.  Can you let us know?
With kind regards,
Chris.
PS Please find the project I used enclosed.
PPS Please use AIMMS 25.3 for testing, as it has an important improvement on Indexed Sets that is used in pr_adapt.
  • Apr 20, 2025 8:33 AM UTC
Hello Chunyang,
Adapted code
With kind regards,
Chris.
Hi Chris!
Thank you so much for this great reply! I updatted my AIMMS to 25.3 and tried it on my project. Using my previous method, running needed_value(scenario, n, t, i) := value(path(r,i), i); alone would take 49.2 seconds.
Now, with the method you suggested, p_needed_value(i_scen, n, t, i) | ( i_scen in _is_scenarios(n,t) ) := p_value( ep_path( _ep_nodeOfScenario( n, t, i_scen ), i), i); running this line to exert all the indices at the same time would only took 62.17 seconds!!!
It greatly improved the efficiency. With my previous method, I will need 23*1000*49.2 seconds to do what I need. Now I only need 62.17 seconds which is amazing!
Best,
Chunyang
