Complex value assignment efficiency problem
Hi I am trying to do a value assignment in AIMMS. Here is the example:
t and i are both the index of set time. n and r are the index for set Node. NodeInTime, needed_value are predetermined parameters. scenario is parameter changing in the process. noted_scenarios_index is a subset of Node. path is a mapping between index (r,t) and set Node.
for (n,t)| t<>first(time) and n<=NodeInTime(t) do
   scenario := 1;
   noted_scenarios_index := {r | r <= NodeInTime(t) and path(r, t) = n};
   for r in noted_scenarios_index do
        needed_value(scenario, n, t, i) := value(path(r,i), i);
        scenario := scenario + 1;
   endfor;
endfor;
I used debug move to check and surprisingly, the slowest part is:
when it runs to this line, ‘scenario’, ‘n’, ‘t’ are determined and it took more than 30s to run this line….. So I don’t understand why it’s so slow.
I also tried using an additional parameter like:
addition(i) := value(path(r,i), i);
needed_value(scenario, n, t, i) := addition(i);
and  addition(i) := value(path(r,i), i); runs quite fast.
However, needed_value(scenario, n, t, i) := addition(i); still runs very slow.
Can you give me some suggestion on how to improve the assignment speed?
Chris Kuip
Hello Chunyang,
The AIMMS parallel sparse execution engine is designed to handle large amounts of sparse data quickly.  As a consequence, each time the execution of an assignment statement starts, there is some preparation time.
The tactic to write efficient code is to avoid for loops -
let each execution of an assignment handle as much data as possible.
For the example at hand, Inside the for loops the input identifiers nodeInTime, p_value, and path do not change, and the parameter scenario and set noted_scenario_index are merely used as temporaries.
Instead of re-using these temporaries many times, the following code expands their use
over the domain (n,t) of valid tuples; consequently avoiding repeated assignment preparation times.
Adapted code
I didn't have data, so I cannot predict the time / memory effect of this code change for your application.  Can you let us know?
With kind regards,
Chris.
PS Please find the project I used enclosed.
PPS Please use AIMMS 25.3 for testing, as it has an important improvement on Indexed Sets that is used in pr_adapt.
  • April 20, 2025
Hello Chunyang,
Adapted code
With kind regards,
Chris.
Hi Chris!
Thank you so much for this great reply! I updatted my AIMMS to 25.3 and tried it on my project. Using my previous method, running needed_value(scenario, n, t, i) := value(path(r,i), i); alone would take 49.2 seconds.
Now, with the method you suggested, p_needed_value(i_scen, n, t, i) | ( i_scen in _is_scenarios(n,t) ) := p_value( ep_path( _ep_nodeOfScenario( n, t, i_scen ), i), i); running this line to exert all the indices at the same time would only took 62.17 seconds!!!
It greatly improved the efficiency. With my previous method, I will need 23*1000*49.2 seconds to do what I need. Now I only need 62.17 seconds which is amazing!
Best,
Chunyang
