converting parameter to index
  • Mar 26, 2025 5:51 PM UTC
  • 48 views
Forum|alt.badge.img+1
I have a parameter read from a CSV file. The first column contains the index list, and the other three columns contain the data. However, I need to use the second column as a second index to differentiate between each hour after the parameter is loaded. I was wondering how this can be done in AIMMS. Please note that using the second column as an index in the first place when I am reading the the CSV file is not viable due to other constraints. Please see the attached photo for a better understanding of the issue.
Thank you.
Best answer by gabiservidone
Hi ​@bestwayyy
Here (https://documentation.aimms.com/dataexchange/using.html#example-csv-mapping) you can find an example how to import CSV using DEX library. In this example, we use parameters indexed in two sets, exactly what you wish to achieve.
Hope this helps!
Hi ​@bestwayyy
Hope this helps!
