csv export unit
  • June 6, 2019
  • 107 views
I use the CSVExport DLLs to export data to CSV.
How to set the unit?
For example, [$/year] is converted to [$/second].
I would like to export using the unit [$/year].
Main problem here is that I loose accuracy when converting back to [$/year].
Thanks.
Jess Es
  • Grand Master
  • June 20, 2019
Hi @wiet you may find the answer you need in the Language Reference in section 32 (Units of Measurement). There's quite a lot of information there, but please let us know if you need more help.
Jess Es
  • Grand Master
  • June 28, 2019
Hi @wiet , did you find the answer you needed? How did it work?
