Declaring identifiers
  • January 13, 2021
  • 106 views
I am getiing an error :
The undeclared "1" is not an index.
I am on the declaring identifiers portion of the course building my 1st AIMMS app.
Best answer by Anonymous
‘1’ is a numerical value, and can not be an index. An index is typically a letter. For example a set called Customers has an index ‘c’ after which you can create a parameter Demand over the index ‘c’: Demand(c).
Hope this helps.
  • January 13, 2021
Hope this helps.
Thank you so much for your help.
