Error: PrintStartReport
  • May 20, 2024 4:27 PM UTC
  • 41 views
When a ‘print’ button is pressed, an error message pops up as shown below:
Code under the procedure as shown:
PR_Verify_PDF_Printer;
PrintStartReport(sp_WeeklyReport_Cover_Title);
! Print cover
PrintPage("r::Weekly Report Cover");
! Print summary
PrintPage("r::Weekly Report Summary");
for i_WeeklyReport_PrintableMonth do
    ! Set month
    ep_WeeklyReport_Month := i_WeeklyReport_PrintableMonth;
    ! Generate report
    pr_WeeklyReport_GenerateReport;
    for i_Report_PrintableAffiliate do
        ! Set affiliate
        ep_WeeklyReport_Affiliate := i_Report_PrintableAffiliate;
        ! Generate Affiliate report
        pr_WeeklyReport_GenerateAffiliateReport;
        ! Print page
        PrintPage("r::Weekly Report");
        if p_WeeklyReport_PrintExtraGraphs then
            ! Print page 2
            PrintPage("r::Weekly Report 2");
        endif;
    endfor;
    ! Print monthly totals page
    PrintPage("r::Weekly Report Month Total");
    pr_WeeklyReport_ClearTotals;
endfor;
PrintEndReport();
What might be causing it? How does one resolve this issue?
Best answer by gabiservidone
Hi @NajwaFarhana, can you debug this procedure to know which line this error happens? But it seems you are trying to use a PDF printer you don’t have installed. Go to File > Print Setup and check the settings there.
