Find ArgMax in a 2-dimensional Parameter
so with the ArgMax function I can find the maximum value out of a Parameter of numbers like this:
ArgMax(i, SomeParamter(i))
However I would like to find the maximum value in a 2-dimensional Paramter. So ideally I would like to do something like this:
ArgMax((i,j), Some2DimensionalParamter(i,j))
This is not possible though, because apperently only one index is permitted for the iterative operator argmax.
Does anyone have an idea how this could be done?
Thank you!
Best answer by mateusarakawa
Hi, @Gergely.
You should use max function instead.
max((i,j) | Some2DimensionalParamter(i,j), Some2DimensionalParamter(i,j))
ArgMax returns the element (i OR j) that has the maximum value, not the value.
mateusarakawa
Hi, @Gergely.
  • July 14, 2020
Awesome, that solved the issue. Thank you very much!
