Find ArgMax in a 2-dimensional Parameter
  • Jul 14, 2020 12:15 PM UTC
  • 327 views
so with the ArgMax function I can find the maximum value out of a Parameter of numbers like this:
ArgMax(i, SomeParamter(i))
However I would like to find the maximum value in a 2-dimensional Paramter. So ideally I would like to do something like this:
ArgMax((i,j), Some2DimensionalParamter(i,j))
This is not possible though, because apperently only one index is permitted for the iterative operator argmax.
Does anyone have an idea how this could be done?
Thank you!
Best answer by mateusarakawa
Hi, @Gergely.
You should use max function instead.
max((i,j) | Some2DimensionalParamter(i,j), Some2DimensionalParamter(i,j))
ArgMax returns the element (i OR j) that has the maximum value, not the value.
mateusarakawa
  • Jul 14, 2020 1:05 PM UTC
Hi, @Gergely.
  • Jul 14, 2020 3:00 PM UTC
Awesome, that solved the issue. Thank you very much!
