Font size in AIMMS
Is it possible to change the font size in AIMMS?
Best answer by Patrick
Unfortunately, you cannot change the font size in AIMMS itself, as it uses the Windows settings for this. In the display settings of Windows, you can change the scale and layout.
Especially when you are using a relatively small high-resolution screen, it is advised to set the scaling to 125% instead of the default 100 %.
View originalEspecially when you are using a relatively small high-resolution screen, it is advised to set the scaling to 125% instead of the default 100 %.
