Get the formula of a cell using AXLL
  • May 4, 2026
  • 55 views
When using the AIMMS Excel library (AXLL), is it possible to determine whether a cell is a formula or not?
There is an explicit WriteFormula function in the library, but I don’t see anything that gives me information about whether a cell is an entered value or whether it is a formula.
I am currently reading in an excel file and need to handle these two situations differently: majority of cells in a range are defined by a formula, but some are manually overruled (i.e. just an entered value) and I need to know which ones are overruled and which ones not.
Best answer by Chris Kuip
Hello Guido,
Using the AimmsXL library, reading the formulas of a cell is indeed not possible.
With the pyaimms library, and the Python library openpyxl, this is possible, see attached AIMMS project.
Perhaps interesting: in the actual call to the Python function, its argument names are used:
read_formula_text(workbook=\"wb.xlsx\",sheet=\"Sheet1\",cell=\"A1\")
Does this help?
With kind regards,
Chris
Chris Kuip
  • May 9, 2026
Hello Guido,
Does this help?
With kind regards,
Chris
  • May 11, 2026
Thanks Chris,
this does solve the problem, though I was hoping there would have been a more AIMMS internal way of solving it.
Guido
