How-To
How to Change Syntax Highlighting and Display Options
  • May 8, 2019 7:27 PM UTC
  • 68 views
Jess Es
AIMMS uses a default syntax highlighting theme to help you quickly interpret a definition visually in the AIMMS Editor.
You can customize the colors displayed for types of identifiers in the editor.
For example, in the image below, the variable Assignments is highlighted green.
Read more...
