How-To
How to Convert an Audio File with IBM API
  • August 23, 2019
  • 139 views
Jess Es
This article contains an overview of how to use IBM APIs with AIMMS projects, and an example using the Speech-to-Text API.
IBM is known for their hardware and software, but they also provide a lot of APIs on the IBM Cloud. Their IBM Cloud Docs: APIs provides all the specifications for each API.
Here we'll use the Speech-To-Text API. By sending an audio file, we’ll be able to obtain the script of this video.
Prerequisites
Read more...
Chris Kuip
The article and example are adapted:
  • Using Data Exchange library to read the JSON file
  • Application has a WebUI
  • When published, the API Key is read from AIMMS PRO Storage.
