Dear all,
I have a matrix T(i,j,k,s).
I want that for each s, i and j are equal.
How can I do this?
Best
View originalDear all,
How can I do this?
Best
View originalI want that for each s, i and j are equal.
Your identifier T has 4 indices (i,j,k, s)
What do you want to happen with k ?
Dear
also k should be the same.
Best
GL
k cannot be the same, k will take values of whichever set it belongs to.
T(i,j,k,s) means
T(1,1,1,1), T(1,2,1,1), T(1,2,2,1) and so on and each of these will have a data value.
If you want an index domain for each s and values of i,j,k are equal - Then
index domain: (i,j,k,s) | ord(i) = ord(j) = ord(k)
This will create only those combinations (1,1,1,s), (2,2,2,s) and so on
Dear
how can I write this in aimms?
I have to select the constraint and then what can I write?
Best
GL
Looks like you want to have a constraint which enforces
for a given s, values of T must be equal for all (i, j, k)
T(i1,j1,k1,s1) = T(i2,j1,k1,s1) and something.
This is similar to your other post, please try not to create duplicate posts.
Create extra indices in your sets I, J, K and use the instructions given in https://community.aimms.com/aimms-developer-12/non-anticipativity-constraint-440#post1027
