How to fill the final results of sudoku into single matrix
  • Dec 13, 2021 2:07 PM UTC
  • 149 views
Above is my sudoku result how to fill the above result into one single matrix with all values..
Any feedback please
Best answer by MarcelRoelofs
The easiest way is to create a element parameter Solution(r,c) into the set assiocated with the index v.
Then you can easily fill it through the assignment
Solution(r,c) := first(v | x(r,c,v));
MarcelRoelofs
  • Dec 13, 2021 11:09 PM UTC
