As a modeler, you can find detailed logs to analyze an issue before reporting it to support or on the community.
AIMMS comes with loggers, a logging feature somewhat similar to the log4j technology.
A good tactic for analyzing these logs is to scan for oERROR] or . When an error or warning is related to the issue you are analyzing, check the lines just above it.
This article provides two files that are templates in creating this information.
Read more...
Be the first to reply!
