How to interrupt a procedure with an if condition?
  • November 8, 2021
  • 100 views
afattahi
I want to interrupt a procedure with an if condition. For example:
if (a condition) then
   TestProcedure1;
else
   *interrupt current procedure;
endif;
I know I can use BREAK; to stop the loops. But how can I stop a procedure?
Best answer by MarcelRoelofs
@afattahi
Depending on what you want, you can call the “return” statement with or without a return value, or if you want to indicate an error, you can call “raise error ...” which you can then subsequently catch in a block-on-error statement.
MarcelRoelofs
  • November 8, 2021
@afattahi
