With AIMMS it is possible to interrupt long running executions with the keyboard shortcut
code:
CTRL+ Shift + S
. However, this shortcut key only works between two executed statements or two generated constraints, or between solver iterations while running the solve statement.
In cases where the keyboard shortcut doesn't work, you can use the AIMMS Interrupt Tool, which can also interrupt long running statements.
Read more...
Be the first to reply!
