How-To
How to Model Rounded Variables
  • Jan 18, 2020 12:00 AM UTC
  • 88 views
Jess Es
There might be cases where you need to model a variable var1 as the closest integer to another variable or parameter value.
Essentially, a constraint like:
var1 = Round(value)
However, using the Round() function in a constraint is not allowed in a mixed integer program and results in an error message, especially if value is also a variable.
We can get around this restriction with the help of some auxiliary variables.
Read more...
