How-To
How to monitor identifiers for changes
  • June 5, 2019
  • 49 views
Jess Es
By default, AIMMS asks you whether you want to save changes to data when you close your project. This behavior depends on which data categories and case type are currently active.
You can also use the data change monitor functions to check when there are changes in a given subset of identifiers in your model since the last time you checked, based on a data category and case type.
Read more...
