how to read multi-dimensional data from excel
  • Apr 13, 2021 9:39 AM UTC
  • 280 views
I want to read data for a parameter P(x,y) from excel file. The parameter is two dimensional.
And the data lies in one of the sheet(say Demand) of a excel file(say DataFile).
I have tried ReadList but it is not working as the range of x lies in  A2:A50 and the range of y lies in E2:E50 and data lies in T2:T50.
Help me to read the data with out creating another sheet.
Best answer by MarcelRoelofs
Alternatively, use the DataExchange library and bind column A to x, column E to y and map column T to P. I assume the names to bind/map to can be found in header (i.e. row 1) of those columns.
  • Apr 13, 2021 10:13 AM UTC
Hi @roy,
Please check out:
MarcelRoelofs
  • Apr 13, 2021 9:36 PM UTC
Going forward, @MarcelRoelofs’ suggestion is even better as it provides more general way to exchange data; therefore also making it possible to decide to go to other formats later (should this be important).
Might you be interested to learn more, check out this post:
