How to represent a string parameter values in different lines in WebUI
  • Mar 13, 2023 11:31 AM UTC
  • 108 views
I have a string parameter as per the following data
optimal
feasible
infeasible
I would like to show it in the WebUI in the same way but it is coming as
optimalfeasibleinfeasible
Kindly help.
Hi @RwitamJ
I’m assuming you are trying to present the content in your String Parameter over a Text widget.
There was indeed an issue with Text widget, that it did not always take newline characters into account. This has been resolved with 4.92.5 version. See the release notes.
Your issue should be resolved with the latest AIMMS version.
Do let us know if this helped!
Madhu Krishnappa
AIMMS WebUI Product Owner
Madhu Krishnappa
Hi @RwitamJ
Madhu Krishnappa
