How-To
How to Save a Case from an AIMMS Procedure
  • Jul 3, 2019 10:44 PM UTC
  • 113 views
Jess Es
There are times you might want to save a case from within a procedure.
For example, let’s say you want to run multiple scenarios and store the result of each one to a separate case. Instead of manually saving a case after running each scenario, you can save cases automatically with a procedure.
That way, you can run a procedure that solves all your scenarios and saves cases after each solve, and let it run unattended.
Read more...
